Lost product code card.
Hello. I need to transfer my single Mathcad 15 licence to a new PC.
Unfortunately i lost Product Code Card that is nessesery to renew licence for a new PC.
I still have originally generated licence files on old PC.
What can i do now ?
Kind Regards.
Tom
Try to contact with PTC tech support by using "Mathcad Support Center": http://www.ptc.com/support/mathcad_supportCenter.htm
Unfortunately, to contact "Mathcad Support Center" i also need to know Product Code which i don't have.
When I click that link it takes me to Mathcad Installation & Licensing Support Centre page which requires a login. Once you have logged in with your PTC account you should be able to open a case with PTC or transfer a license. I don't know my product code either.
23-Emerald V
If you still have your old PC with Mathcad 15 running on it, then go to "Help/About Mathcad" - your product code should be listed at the bottom of the help dialog.
Stuart
Unfortunately - Mathcad 15 on old PC was uninstalled by other user.
The only thing that left was the licence files and empty directory....
Sounds bad. Apart from the old license file, do you have some other proof of purchase?
I guess transferring the old network interface card to the new machine is not an option as it probably will be onboard, right?
It might be wroth contacting your re-seller or Andrew McGough at PTC who has helped me in the past.
McGough, Andrew <->
Thank you for this contact...
No problem at all. Please let us know how you get on.
Hi Tomasz,
Try to use "Reconfigure Software Licenses" option on PTC's site to transfer your license file in new PC (this option are move/split PTC's products from one machine to another): https://support.ptc.com/appserver/lm/rsl/reconfig.jsp
