Mar 13, 2012 5:02 PM UTC
Low resolution Excel component
I want to create a table that has labels across the top row and labels down the left column. It seems that a regular Mathcad table will not allow this because it thinks my labels in the left column are undefined variables. I would like to use an Exel component for the table, but the table prints kind of fuzzy. Is there a way to get a higher resolution Excel component? Or just a better way in general to enter such a table? Thanks
wayneAnswer
Mar 13, 2012 5:58 PM UTC
Without using Excel, you can do simethin like the attached
wayne12-AmethystAnswer
Erica1-VisitorAuthor
Mar 13, 2012 7:06 PM UTC
Thanks for your document Wayne. How did you display it as a table with borders? Is that still possible with Prime 2.0?
Mar 13, 2012 7:33 PM UTC
I don't have Prime 2 right no, but in M15
select the matrix, the Format>Result>Display Options>Matrix display styl
to get rid of (or show) the automaitc column and row headings, right click on the talbe and slelct properties from the drop down menu.
