MATCH CAD PRIME 7 MATH REGION CHORTCUT BROKEN
After windows update, i can no longer use the CTRL+SHIFT+M shortcut to add a math region on the canvas or in a text region.
I use this shortcut heavily every day, anyone else have the same issue?
tslewisAnswer
PHEW.
OK, I fixed it by doing a clean boot of my computer. Multiple restarts through windows did not fix the issue.
To get a clean boot, shut down windows through the start bar and then physically turn on the computer again.
What Windows OS are you using?
tslewis13-AquamarineAuthor
Windows 10, been using it without any issues for over 2 years
Version 10.0.19042 Build 19042
CTRL+SHIFT+T for text region works just the math region one is disabled, very annoying and severely limits how i use Mathcad
tslewis13-AquamarineAuthorAnswer
PHEW.
Thanks for this tip in the end!
