Dale_Rosema
Feb 22, 2013 8:50 PM UTC
Math expression in a note (annotation)
I have a note that calls for ## holes in the part.
The print dimensions the spacing between the first two holes and says (## - 1) spaces.
I looked through the tips for text thread ( http://communities.ptc.com/message/185313#185313 ) but couldn't find anything.
Is there a way to perform this math within the note?
i.e. 14 holes there for 13 spaces (where the 13 is the pattern p## less one).
Thanks, Dale
Dale_Rosema
Feb 22, 2013 9:26 PM UTC
"Spacenumber=p117-1" then use "&spacenumber.[0]" - Don't forget to trucate it since it is an integer. Thanks,
Feb 22, 2013 8:59 PM UTC
Yes, you do the math in relations and then use that new relation variable in the note.
Something like "spacenumber=pattern_qty-1" then "&spacenumber" can be used in the note
Dale_Rosema
Feb 22, 2013 9:03 PM UTC
What if the first item (pattern_qty) is not a parameter in the part, but just the dimension from the pattern feature? Is it then, "spaenumber=p117-1" then use "&spacenumver"? (Where p117 if the dimension for the quantity in the pattern).
Feb 22, 2013 9:07 PM UTC
In relations, yes.
