Math programming
Dear community,
I am carrying out the coding of the optimization task in Matlab, from the attached sheet, to the Mathcad language. But I am stuck at this point.
You can support me in this task.
Any help is appreciated in advance.
CarlosRomero
terryhendicott
Hi Carlos
Regarding the intlinprog() function, Mathcad can apply an optimization algorithm that has already been developed.
Yes it can, maximise and minimise function in a solve block should work.
I ask if with Mathcad you can't write a utility or function equivalent to Matlab's sparse function?
Sparse is a definition scheme of an array that utilizes storage schemes that only contain the non-zero entries in the array.  Any function that uses sparse arrays and/or matrix arithmetic using them must be written to do so.  I suggest you use Mathcad's dense matrix only that may limit the size of problem able to be solved.
Cheers
Terry
xloc is a 20-element vector with elements numbered from 1 to 20 (because ORIGIN is set to 1).
You try to access an element with an index larger than 20 - hence the error.
Similar wih yloc, which is a 21.element vector.
xloc and yloc would both need to be 40-element vectors for that code to work OK
terryhendicott
Hi Carlos
The matlab programming takes advantage of sparse matrices and the final intlinprog() function that is the heart of the example (last line of matlab code) both of which Prime 9.0 does not have.
Cheers
Terry
terryhendicott
This is a similar problem? factories, warehouse, stores represented by ,Feeds, pools, and products.
https://community.ptc.com/t5/Mathcad/Pooling-problem-optimization/td-p/908732
Cheers
Terry
