Mathcad 14 Graph "traces" internal error
Hi everybody,
I just finished installing Mathacd 14 on my Windows 10 PC.
Whenever I try to click on the traces tab in the graph property windows it crashes with an internal error.
I tried reinstalling and reparing it but neither worked.
I hope you can help me.
mdietrichAnswer
Ok i found a solution.
I uninstalled Mathacad and deleted everything i could find associated with it.
Downloaded the installation again.
Disabled my antivirus program as well as windows firewall
Installed Mathacd in WINXP mode.
Solved the problem for me.
Try right clicking on Mathcad.exe and setting the compatibility mode to Windows XP.
mdietrich1-VisitorAuthor
Ok tried that but it still keeps crashing. tough not with the internal error msg. It's just the generic Windows msg. (Mathacad Application has stopped working)
Did you try any of the other compatibility settings?
What exactly service release of Mathcad 14 are you using?
I downloaded it from Mathcad Downloads‌ the M020 release.
Is there any chance for you to install the latest Mathcad 15 M045 service release? You can find it here: Thank You for Your Interest in PTC Mathcad 15 | PTC
-MFra-
Now the 14 is no longer in production. You had better download the 15 with Prime 3.1 student edition.
In addition, the 14 works well with Windows XP.
A license for version 14 will not work with version 15
mdietrich1-VisitorAuthorAnswer
Could you please mark your own answer as correct. It will make it easier for others with the same problem to find the solution.
done thanks for your help anyways
