3-Newcomer
Mathcad 14 Install and license not working
I recently had my computer refurbished and am goin g through reloading my software. Mathcad 14 is not cooperating. I reinstalled, provided the code that came with the CD and uninstalled the license from the previous computer and redownloaded the new license file. The new license file has the correct HOST ID, but mathcad tells me that it isn't correct and redirects me to select a new file. ? COuld it be that the license fiel doesn't include Mathcad? can't understand why? Pleas
my suggestion follows:
  • open Command prompt window
  • run ipconfig /all > ip.txt command
  • open ip.txt in Notepad and check whether HOST ID is present
  • network card with HOST ID assigned must be connected to network (if it is disconnected then Mathcad will not find it)
23-Emerald V
I'm confident that your license file includes Mathcad. But I'm not so confident that it still is valid. I think you should read this:
https://community.ptc.com/t5/Mathcad-Tips/Official-PTC-Mathcad-15-and-Prime-1-6-End-of-Sale-Announcement/ta-p/818870
If you have a perpetual license for Mathcad 14, you should contact PTC support...
adept3-NewcomerAuthor
3-Newcomer
I own a perpetual license from before PTC took over Mathcad, but they still managed licenses. Contact PTC? How?
Go to this webpage: eSupport | PTC
Under Popular Tasks, select Manage Licenses
On the right select Case Logger to open a support case.
3-Newcomer
Thanks Martin,
The only network connection that is connected was the HOST ID that I used to move the license and this is confirmed Flex install manager list the Host ID at the base of it's dialog box window.
@adept wrote:
Thanks Martin,
it is not clear from your answer if Mathcad 14 works, now.
