MathCAD 15 Client can't grab license from server.
We have a floating license set up on our server and in the LMTools program the status says 1 license availible.
There has been a rule added to the firewall on the server to open port 7788.
When configuring the client, I've tried using both the server name and the server IP address to no avail.
Whe also have an Autodesk Simulation license issued on another instance of LMTools on the same server. Would this be causing an issue?
What else might I try?
Have you talked th Mathcad Support directly?
TTFN
Our Support Subscription has expired since we bougth the product. I can't even access the how-to page.
I guess my main question is can teo installs of LmTools runs side-by-side?
When I reconfigured the MatchCAD linces I get the attached warning.Matchcad+Warning.png
