Mathcad 15 - Formatting issues for two separate users
Coworker and I are using Mathcad 15.  I made changes to a Mathcad sheet where margins look fine and everything is correct; and the coworker opens and saves changes but figures (jpeg images) and various formatting issues with text and margins change.  I open up the last saved document and everything is out of place.  Anyone experience this issue?
This sounds a lot like a problem I had a while ago (on Mathcad 13).  See this post: https://community.ptc.com/t5/PTC-Mathcad-Questions/Image-Locations/m-p/327621
Sorry I didn't have a better solution to the problem.
Similar problems were reported many times in the past.
The reason for those effects may be of you and your coworker using different zoom settings im Mathcad.
Problems in the past often were related to working with zoom factors different from the standard 100%.
