Mathcad 15 Header In Landscape Mode
I want to create a Mathcad 15 document in landscape mode. Which is easy to do, but I find the position of the text in the header is fixed. I am not able to change the position of the text in the header with the Top Margin box in Page Setup. It always stays the same,
I want to be able to put the printed document in a two hole cardboard binder, but want to have the header line visible. The folder cover overlaps the top of the page by 7/8 inches.
(I know I could use the footer instead but I would have to modify a lot of documents going into the same folder so I would rather not do that.)
Is it possible to change the position of the text in the header? See attached.
Bill
BillDumke1-VisitorAuthor
Whooops, I attached the wrong document. How do I attach the correct one? I don't see the attachment option in this reply.
Bill
Bill, you can Edit discussion and attach the correct document. Should be an option in your Actions toolbox
Thanks for the help, Dan. Unfortunately, I have no Edit Discussion option or anything similar listed in the Actions toolbox, although I am logged in OK.
I wonder if my account is corrupted. That happened once before. Let me try my other account.
Bill
No replies. I guess that means there is no solution. I remember back when I bought Mathcad 3.1. It thought it would be great for publishing my work. But it wasn't, and Mathcad 15 still isn't. I will have to go copying and pasting into Word again which is a pain.
It would be nice if PTC would put a few additional features into Mathcad for publishing documents like being able to move the headers and footers up and down. Another feature that would be handy is the use of sections that could be set in protrait or landscape mode, But I doubt it will ever happen.
Bill
Sorry Bill missed this post. It seems it cannot be changed which is strange.
You could just have the Header located with your sheet and locate it in the position you want.
Mike
Bill,
I'm not clear on what you are trying to do. I can move the header down on the page by adding linespaces above each part. We will be adding more flexibility to headers/footers in Mathcad Prime 3.0.
Mona
Mona,
Even when the page is set to landscape.
Any ideas as of yet?
Mike
