Jun 29, 2022 10:03 PM UTC
Maybe that way:
Jun 29, 2022 10:06 PM UTC
Or you may redefine your function f(..) to return zero for even values of n:
or, as a variation, you may put the branch into the sum instead of the function f:
And as my last solution for now you may do without the summation operator and program the summation yourself:
The last will not work for a=1 unless you add some kind of branch (if).
8-Gravel
Jul 5, 2022 1:57 PM UTC
I tried to follow the same method in my original programming but the solution does not converge while matlab can
Can you share your views
