Mathcad 15 push button keeps executing without clicking it
- 3 replies
- 2530 views
- Translate All
Dear all,
Attached is a sample mathcad sheet, where I created a push button which should write some data to an excel sheet. But if I enable evaluation, my mathcad automatically runs the script in that push button and writes data to excel file (irrespective of whether I click the button or not).
The basic idea is, I would like to make lots of iterations / changes in mathcad, and once I am happy with the output, I would like to write the data to excel (by clicking a button). I wouldn't want the excel file to keep getting updated every time I make some changes to the mathcad sheet.
Required output:
Output(0) = "Yes"
Output(1) = worksheet.name
But Output(0) variable is by default, defined as "No" and I don't want it to change to "yes" unless I explicitly click the button (because I used an if statement to write file to excel). Kindly suggest changes / better way to achieve this ?
Your help would be much appreciated !
Many thanks in advance,
Aravind.
