Mathcad 15 sheet edit on the internet.
I am going to serve as teacher assistant in a construcion course at my universty were i will be grading beam design assigment.
I have calculated everything in mathcad 15 so far. The students will have to determine the height of the beam by fullfilling a criteria.
I would like to put my mathcad file on the internet were the students can select the diffrent parameters each student have. mostly diffrent material properties
and there they can see if they have choosen a height that fullfilles the specifed criterita.
Basiclly I want the student to choose their parameters from a dropdown menu or something and then the calculations will be performed based on that and
this i want them to be able to do on a webpage. is that possible?
I think Mathcad Calculation Serve can solve your problem
Try please
http://twt.mpei.ac.ru/MCS/Worksheets/SelBeam/Konsol.xmcd
