Mathcad 15 with windows 10
So i have a dell laptop that recently upgraded to windows 10  from windows 8. The only way we can get it to work with Mathcad 15 so far is to run it  in windows 7 compatibility mode but it takes a long time to start but when going to page setup option under "File" it freezes for  a few seconds and then looks like its about to open but then nothing happens. Other than that seems to work fine. Any suggestions on how to fix this?
Hi Alex,
Try to repair it Mathcad 15: "Control Panel" --> "Add/Remove" --> right click on Mathcad15 icon and select "Repair".
Tried reinstalling it totally and it is still doing the same thing. I should reinforce that only the program freezes, you can still do things in windows when page setup is selected and everything else seems to work okay so far as long as its started in windows 7 compatibility mode.
Are you use the latest service release M040?
