MATHCAD 15 Worksheet libraries
Does anyone know where I could get copies of the PTC MATHCAD 15 worksheets (libraries / Roark's etc)
Im happy to pay etc but the PTC website says they no longer do these.
Thanks all
DJNewman
DJNewmanAnswer
PTC has end-of-saled the worksheet libraries; if you do find someone saying they're willing to sell you them, I'd consider that suspicious and you shouldn't give them your money.
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
DJNewman
DJNewman19-TanzaniteAnswer
This is correct. But I would imagine if you own(ed) Mathcad 15, you do(did) have these files as part of your license, and you can convert them into Prime worksheets. I do recall a PTC employee sharing this approach a number of years ago when this same topic came-up in a users' meeting when Prime was very early in its release. Unless there is now some sort of a legal issue with that, this would be a solution.
This unfortuneatly doens't work for sheet that contain protected areas (which almost all of the Roark sheets do) as those are not supported in Prime.  So baciscally users are f'd. I have a lot of Roark sheet that used to work just fine and now are useless as I can no longer convert them into Prime.
