MathCad 3.1 - File not supported
- 7 replies
- 3479 views
- Translate All
Hello
I have been using MathCad 3.1 for about 5-6 months as a tool for calculating and taking notes in physics, math, electrical engineering and so on. Most of my .mcdx documents contains a wide variety of text, calculations, plots and images. Usually I have no problems with MathCad. However i cannot open a specifik file containing valuable notes on electrical and magnetic fields. The content is valuable to me, mainly because my exam on the subject is in 2 days, but I can get by without.
But I would really like to know the cause of this problem, because if this is a consistent problem and i will, for no appearent reason, loose some files every now and then, then i cannot continue using MathCad. It could completely ruin and exam.
The nature of the problem:
I have not opened the file for at least a month. It worked fine the last time though. Now when i try to open it, it says "The file type is not supported" and it points to a log file. After searching for a solution on the internet i found that a mcdx file is actually a zip file. However i cannot open it as a zip file. Not when it is as .mcdx file and not when i rename it to a .zip file. Winzip and Winrar both reports that the file is either not supported or damaged.
I then tried using Diskinternals ZIP repair and also Zip Rapair Pro to repair the file. Both programs does not register any files within the zip(even though its size is over 6mb) file and just spits out empty ZIP files(size 0 bytes).
Trying to open the file, with either zip or mcdx extension, in notepad/wordpad doesent work either. I didnt expect it too either. It just shows thousands of blank pages. This is the extent of my mcdx related knowledge. At this point i do not expect to ever open this file again, however i would like to know possible causes, so that I can either avoid this problem in the future or reevaluate if MathCad is worth the risk of potential lost data. It might be worth mentioning that i am using Dropbox to synchronize my laptop and desktop, however this has never corrupted a file before, MathCad file or not.
Both the mcdx file and the log file is attached to this post. If anyone can come up with a possible answer I would be very grateful.
Many thanks
Emil
