Mar 1, 2025 5:29 PM UTC
Mathcad Community Challenge March 2025 - Magnetism!
This month’s challenge is based on magnetism. Create a Mathcad worksheet to answer any or all of the following:
Basic Challenge:
  1. What is the magnetic field strength of 15 Ampere current in a wire at a distance of 0.25 meters?
  2. How many turns of wire will be needed to create an electromagnet capable of lifting 1 kilogram of ferrous material if the current is 0.25 Amperes, the lifting face of the magnet is a circle with a diameter of 5 cm, and the length of the coil is 0.1 m? Assume a relative magnetic permeability of 750.
  3. What is the total magnetic energy of the Earth? (Assume a magnetic field strength between 0.22 and 0.67 Gauss.)
One resource for the equations to solve these problems is NASA’s Magnetic Math ebook.
Graphing Challenge
Create a 3D plot of the force generated by an electromagnet as a function of electrical current and surface area of the lifting face of the electromagnet. (Choose any values you want for the other parameters of the electromagnet.)
Creative hard challenge: can you represent a magnetic field in a plot or chart in Mathcad? (Seriously, I have no idea how I would approach this.)
Advanced Challenge
The earth’s magnetic field currently decays approximately 6.3% per century. How many years is it until earth’s magnetic field will be 50% of its current strength assuming (1) linear decay and (2) exponential decay? How long until 25%, 10%, and 1%?
Mathcad Prime 10 Challenge
Incorporate an advanced input control (e.g., sliders, radio buttons, list boxes) into any of the above challenges.
Find the Mathcad Community Challenge Guidelines here!
terryhendicott
Mar 3, 2025 3:02 PM UTC
Hi David,
First attempt
Cheers
Terry
Mar 3, 2025 5:00 PM UTC
Well done!
How about adding arrow heads ?
Orientation is taken from your matrix B
Choose between different arrowhead styles
BTW, when opening your sheet, Prime moans about a region (seems to be one at the bottom) being damaged.
terryhendicott
Mar 3, 2025 9:24 PM UTC
The moans about a region is I cited my source by copying and  pasting text but this included some unprintable characters.
New file has the citation without these characters at the start of the file.
Regards
Terry
ttokoro
Mar 8, 2025 11:22 AM UTC
ttokoro
Mar 9, 2025 10:25 AM UTC
Assuming inside of the coil also filled by material. If not, needs 750*48 turns.
However, Q2 in basic challenge must need more check by others.
t.t.
ttokoro
Mar 14, 2025 6:10 AM UTC
Version 2. Trying to plot line current and its magnetic field lines in 3D.
t.t.
DJNewman
Mar 31, 2025 3:18 PM UTC
Howdy all,
Good news: The challenge will be extended to the end of this week instead of ending today!
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
DJNewman
Apr 22, 2025 4:33 PM UTC
Sorry for the delays; here is the write-up solution blog!
https://www.mathcad.com/en/blogs/community-challenge-magnetism
And y'all have badges (that look a bit different than before, for the better) now too.
I'm currently looking over the May challenge prompt; should be fun.
