Nov 1, 2026 8:11 AM UTC
StickyQuestion
Mathcad Community Challenge November 2026 - Electrical Engineering - RLC Circuit
The final community challenge of 2026 has an electrical engineering theme, combining one subject from college I enjoyed (differential equations), and one that really went over my head (Bode plots). We will use an RLC circuit to explore both. (R is for resistor, L is for inductor, and C is for capacitor.)
Our RLC circuit is in series and consists of a 60 Ohm resistor, a 0.01 Henry inductor, and 100 microfarad capacitor. It has a Direct Current (DC) voltage step of 12 Volts applied at time 0.
Challenge 1: Time Domain Problem (Differential Equations)
  • Write the differential equation governing the capacitor voltage for the RLC circuit.
  • Compute the neper frequency, resonant frequency, and damping ratio.
  • Is this circuit underdamped, critically damped, or overdamped?
Challenge 2: Graphing
Using an XY Plot or Chart Component, graph the capacitor voltage as a function of time.
Challenge 3: Frequency Domain Problem (Bode Plot)
Find the Transfer Function H(s) for this circuit assuming all initial conditions are 0. Construct the Bode plot for magnitude in decibels and phase in degrees as a function of frequency.
Challenge 4: Varying Inputs
Use any Mathcad Input Controls of your choice to allow users to vary any of the inputs that you choose. Consider employing conditional formatting with Input Controls for any feedback (no pun intended) that the worksheet should share with the user (for example, damping).
Find the Mathcad Community Challenge Guidelines here!
Nov 6, 2026 1:44 PM UTC
Not my area of expertise, but here’s my solution anyway:
Bode plot (with the supplied L, R and C values):
Alan
Nov 10, 2026 8:30 AM UTC
Just noticed a silly mistake in my previous worksheet.  Corrected worksheet attached.
Alan
Nov 6, 2026 5:53 PM UTC
Here’s my submission.
Roger
3-Newcomer
Nov 8, 2026 11:18 PM UTC
Please find attached some workings for the November 2026 challenge, mainly the work of many others. Thank you.
23-Emerald I
Nov 11, 2026 6:42 PM UTC
Bit of a curve on Bode Plot(s):
23-Emerald I
Nov 11, 2026 8:21 PM UTC
23-Emerald I
Nov 14, 2026 5:35 PM UTC
Nov 14, 2026 7:02 PM UTC
Parts of your PDF are unreadable.
Instead of
I see
Maybe it helps if you setup your pdf writer to embed the used fonts (at lest the characters used) into the created pdf file. It will blow up the file size but makes it compatible to systems where some used non-standard fonts are not installed.
23-Emerald I
Nov 14, 2026 8:08 PM UTC
My apologies.  I did not realize that this had happened.  (I recall when “print to pdf” meant you saved an image of the printed page; editing or even copying part of the text was not possible.). I was given two choices for pdf printers.  Microsoft print to pdf failed to create a file.  Adobe (who I thought would know how to do this) created this mess.  I have no idea how to adjust this, both programs came preinstalled.
This would be a lot easier if I could just upload the native Mathcad file (Prime 4 express)
Nov 15, 2026 9:53 PM UTC
No need to apologize—I just wanted to point that out. I, too, am not always sure whether the PDFs I create are readable everywhere. After all, as long as the fonts used are installed on the device being used to read them, the problem cold not be shown.
I just noticed that there’s an option in Adobe PDF’s print settings called “Rely on system fonts only,” and there’s a replacement table for different fonts in Adobe PDF’s properties (which, admittedly, I’ve never manually changed—the default is “do not replace”).
I thought to remember a certain option (I suspect from an older version of PDF Writer or the full version of Adobe PDF) to either embed no fonts in generated files, embed all fonts, or embed only the individual characters used.
However, I could no longer find this option on the device I’m currently using (which doesn’t have the full version of Adobe PDF).
Upon closer looking at the mess I see when I open your pdf it looks to me that the problem is not the font but rather the character mapping. No idea how you or me could take control over this when creating the pdf.
?? Didn’t you do that anyway?
And, yes, I agree that I would have expected adobe making a better job, too. At least I would expect an easy to access button where we could set something like “Best compatibility (at the cost of file size)”.
P.S.:
I created PDFs of your Prime file using Microsoft PDF, Adobe PDF and CuteFTP Writer. From the file sizes it looks to me that only Microsoft PDF is embedding fonts (or the reason is a less intense compression of images?). It also looks to me now that your Adobe PDF actually did embed fonts, too. So I am not sure what caused the mess on my side.
Just for reference I attach the three files created (and I  have no idea if they would work OK on other systems...).
