Mathcad express - setting default math formatting?
I'm using Mathcad prime 3.1 express at my school for electrical calculations.
And I am constantly switching between the taps  "MATH" and "Math formatting"
It's really a hazzle..
Things i would like to change is
General should be Decimal or Engineering, Decimal values i need to be (5) not (3) as it is now.
and finally complex numbers should be displayed in polar instead.
I find myself switching the tab almost after each line of writing, and for one assignment i usually fill 2-3 A4 pages.
so it's really getting to me that i can't figure out how to set these things so they STAY that way be default.
Anyone have an idea on how to change the standard values under math formatting?
23-Emerald I
I don't know about EXPRESS, but
In Prime 3.0, you can set formatting for the whole sheet (text and math) by setting your options with nothing on the sheet selected.  (Don't select a text region, just set the text formats you want.  Don't select a math region, just set the display parameters.)  You might investigate creating a template, again, I don't know if EXPRESS will allow that.
23-Emerald I
mvaupell1-VisitorAuthor
I never knew, so when you start a new worksheet, i set the "default" options for that sheet..
Great news, thank you.
I'm unable to try right now, but i will try tomorrow.
