23-Emerald V
May 19, 2020 7:43 PM UTC
Mathcad Ideas - Split Screen
https://community.ptc.com/t5/PTC-Mathcad-Ideas/Split-screen/idi-p/656081
The above link leads to a Mathcad Idea that suggests having split-screen working.  This is something that I've wanted to see in Mathcad for some time (over 13 years, in fact), the lack of which is proving a real nuisance at the moment.  Could some kind, support-paying souls please offer their support for this idea?  Thanks,
Stuart
https://community.ptc.com/t5/PTC-Mathcad/New-Feature-requests/m-p/356451#M139515
(I've got a much bigger list, in case anyone's not interested ...)
Derbigdog
May 19, 2020 8:16 PM UTC
DId you know you can launch one than one instance of Prime at a time? You can load one file in one and then review copy/cut/paste etc into a file for the other.
23-Emerald V
May 19, 2020 9:38 PM UTC
Yes, that is a useful facility when copying/pasting between worksheets.
However, my main use case is working on two different areas of the same sheet, ie change a function near the top and then look down the worksheet to see if the change is having the desired effect, or just having a function's definition in view when I'm trying to work out why some dependent function isn't behaving as I told it to!!! 😉
Unfortunately, in cases like these, multiple instances of Prime don't seem to help. AFAICT, if the same worksheet is open in two instances of Prime, changes to one don't reflect into the other.
Cheers,
Stuart
Derbigdog
May 20, 2020 2:44 AM UTC
Understood. With Mathcad 15 you can put in hyperlinks that allow you to jump back and forth, but still not the flexibility of of real Split Screen.
