MATHCAD PRIME 10 constantly crashing all of a sudden today when using text subscripts
- 7 replies
- 1946 views
- Translate All
Im a heavy long-term user of mathcad. I regularly embed math regions within text regions in my calcs.
Today, I now find whenever I try and copy a math region within a text region mathcad constantly crashes. It never did this before.
A few years ago there was an error PTC was aware that MS caused with an update where you could not copy and paste math regions form a text region into another text region. I wonder if there has been a recent update that has broken mathcad.
I find i can replicate the constant crashing when in a text region contain embedded math regions, if I refer to a math variable using a text and subscript within the text region, It will crash constantly when copying a math region in that text region above the text subscript.
If I use my traditional approach pre-Prime 10 of using a math region to refer to the variable with subscript no issues. ( I typically see MathCAD crash once or twice a year, today its crashed thirty times.)
See attached sheet. Case 1 is my traditional approach. Case 2 is the crash case. Highlight the math region for the expression in Case 2, copy, and Mathcad will crash.
I would suggest if you are mixing math and text regions, then do not use the subscript feature for text as your worksheets will be corrupted.
