Mathcad Prime 10: Excel File Generated by WRITEEXCEL has wrong time stamp
Hello all,
I found out the WRITEEXCEL generate excel file with wrong time stamp. This is my worksheet.
test1.xlsx is a simple file, that contain 4x3 information.
Timestamp generated is 28 March 2009. Anyone facing the same issue?
Regards
LucMeekesAnswer
23-Emerald V
Ah, apparently they've dropped that possibility somewhere between Prime 4 (where it is possible) and Prime 9 (get the same error message as you).
23-Emerald V
Depends on what timestamp you're looking at. Is it the creation date, or the latest access date?
Hello. It is the creation time. I just created test5.xlsx today, but the date for the file is 28 March 2009.
You can try this simple 1 line code, and verify if the date is correct. I still got 28 March 2009.. hmm... weird..
I can't duplicate the issue.
When I create an Excel file via WRITEEXCEl, it gets the correct system date.
You are sure that OS date/time are set correct on your system?
System Date is all correct. I never have this kind of issue, with other software. I'll ask Mathcad Technical support
Might be an Excel problem
See Excel 2013 Incorrect Date Created | Microsoft Learn
