May 10, 2016 4:01 PM UTC
Mathcad Prime 3.0 does freeze after doing smth. like saving.
Hey Guys,
recently I got a license for Mathcad Prime 3.0 (Academical Version) and tried to install Mathcad on my PC.
I had no problems with installing or licensing later on.
First startup also no problem.
But when I am trying to do something with it, it starts freezing and there is no way to get control back.
Mathcad is working on the devices from class mates using the same Operating System.
System Specs (might help you):
Operating System: Windows 10 Home 64bit version 1511 (build 10586.218 for the nerds ^^)
16 GB of Ram and nVidia gForce 960m
and SSD for operating drive
Things I tried already:
.) Run in compatibility mode in windows 8 and 7
.) Reinstall with all Mathcad data removed
.) Install with license.dat
.) Run over internal graphics card (Intel HD 530)
.) Run as Administrator
.) Installed Framework 3.5 and later
Something else I can try?
Hope I havn't forgot something and also hope for a fast help.
Greetings Alexander
Btw.: The reason why I am using Mathcad Prime 3.0 and not 3.1 is just because I got one for 3.0 from my school.
23-Emerald V
May 11, 2016 10:44 AM UTC
You have a 64-bit OS.
Your .NET framework should be, and probably is also 64-bit.
Which edition of Prime 3.0 did you install, 64 or 32-bit?
May 11, 2016 5:58 PM UTC
I installed the 64bit version of Prime but got a 32bit version of .NET framework. i'll try to install the 64bit Framework
Greets Alexander.
23-Emerald V
May 12, 2016 9:22 AM UTC
Please report if that solves the problem.
May 17, 2016 2:04 PM UTC
Please submit your request in "Academic Support Request" form: Academic Case Logger
May 17, 2016 6:23 PM UTC
Ok did. I'll notify you when i've got a solution.
May 18, 2016 8:54 AM UTC
We will wait for feedback from you.
May 27, 2016 8:40 AM UTC
if you can do following test:
  • disconnect current disk
  • connect another empty disk
  • install Windows 10 ... you will get clean operating system
  • install and test Mathcad
If Mathcad works, then the problem is somewhere in current Windows 10 installation ...
MH
May 29, 2016 1:26 PM UTC
Tried this with a Virtual Machine (should be the same effect and I hadn't any drive laying around).
Didn't freeze.
What can I try to get this working? (without Formating the whole drive and reinstall all programms)
May 31, 2016 7:42 AM UTC
Hello Alexander,
What can I try to get this working? (without Formating the whole drive and reinstall all programms) ... that's the right (and simple) question . Unfortunatelly the answer is not so simple. I am sorry I do not have any idea.
MH
