MathCAD Prime 3.0 unit formatting
I am using an excel component with an output to define variables. The variables are then displayed in the worksheet. I am trying to define the units then and it keeps putting 1/m before the mm unit I am trying to specify.
See below:
What do I need to do in order to correct this?
Brad
Werner_EAnswer
You have to redefine the variable using "Core_Depth:=Core_Depth*mm"
Werner_E25-Diamond IAnswer
That is what it was.
Brad
