Mathcad Prime 3.0 units issue
I created a variable in PSI (lbs/in^2)units, multiplied by a unitlesss number. The issue is that my resultant output "Fr" comes up in other format, I just want it to show as PSI, like in the variable. tried "base unit " but nothing changes, please see pic.Thanks
Did you select "Labels" and designated your new unit as a "Unit"? the unit will turn a bold blue color if succesful.
I hope this helps.
Norm
Simply edit the result expression - delete the dislayed unit and replace it by psi. Prime will change the value in front accordingly.
It is because you are passing a variable with units attached to the square root operator. Try removing them before you pass it.
