Mathcad Prime 4 converter fail
I have Prime 4 up and running.  To convert legacy files, I installed Mathcad 15 like is says it needs.  Both work fine. However, the converter feature just doesn't work.  Every legacy file I try to convert says converstion failed, process aborted.  No other info.  I have not gotten any legacy file to convert.  So far conversion to Prime has been a bust.  These are simple files, maybe a jpg image or two.  Very Frustrating.
Curt Fortenberry
23-Emerald I
Can you open the file in Mathcad 15?
Sounds like something went wrong in your installation. But to be sure you may post here one of the legacy files which failed. If it failed for us, too, its the file. If not its your installation.
arrphoto1-VisitorAuthor
I've tried to attach a simple file, no graphics, and one that fails the converter process (actually, all do but this was a very simple equation file).  The file opens fine in MCAD 15.  But when I attach the file here to post, I get an error saying "content type does not match file extension".  Odd.  I did try to copy and paste from 15 to Prime, but it only comes in as a graphic.
Curt Fortenberry
This new forum software has many drawbacks and we hope that PTC will get things sorted soon.
At the time being most of us (but not all) are bot able to uplod Mathcad or Prime files directly and get the very same error message you reported (see the discussion here).
Workaround so far is to put the file in a zip or rar archive and upload the archive 😞
For INFO:
I'm using MP4.0 and MC15-Version M045.
Conversion without any problems.
EDIT: added Files
Guess it is an installation problem.
