Mathcad Prime 5.0.0: Subscripts in Text Blocks
Hello PTC Community,
I have switched form Mathcad15 to Mathcad Prime 5.0.0 but I am unable to add subscripts in text blocks when using the Prime version. Has the feature been removed from the Mathcad Prime versions?
23-Emerald V
Yes, that is one of the new features of Prime with respect to (good old, real) Mathcad:
A lot of functionality is NOT available.
saadhere1-VisitorAuthor
Is there any possible workaround?
23-Emerald V
Certain characters are available as superscripts a ² for example, otherwise choose a different font for your sub/superscripts.
one workaround is to use the character map of windows. There you'll find a font called "Mathcad Unimath" which provides sub and superscripts; numbers only though.
Another workaround is to generate your own character set of subscripts and use this.
Believe it or not - this was a recommende procedure by PTC
Raiko
As I've just begun an effort to re-visit Prime (with the latest version 6) to see how usable it is, I've run across this issue too...really PTC? A big focus on Prime's development was to make it easier to create technical documents...but you took away that very convenient sub & super script text button we had for many years. Yes, entering a Math expression into a text region does work, but why should we have to copy & paste and mix these regions?
PTC - are you listening???
23-Emerald I
No, they're not listening.
Sorry!
