3-Newcomer
MathCad Prime 9.0 - Exporting data set Excel
- 2 replies
- 2194 views
- Translate All
I'm trying to get a set of data in a form where I can copy and paste it into a another application. It is two columns of data. The first is a range variable. The second is a calculation on the range variable.
I've tried to get the two columns of data into an embedded Excel Component but just can't see how to do it. Getting confused between ranges versus vectors/matrices.
Is there a way of converting the range variable into a vector?
Any help would be much appreciated.
I thought if you can see the indices, it is a vector/matrix?
Dave
