Mathcad - Text in table cells
I wanted to create a table with text and numbers and then be able to sum the numbers.  Such as:
    Item          Wt
   Motor       100
   Bearing      20
   Mount       220
TotalWeight:= Sum Wt
But it is complaining that "Motor" etc. are undefined variables.
I could created just a single column table to hold the weights and then align it against a series of text boxes but that does not feel right.
Thanks for your help,
   Robin
It's best if you attach your file and/or include a snapshot.
You likely just need to put Motor, Bearing, & Mount in quotes:
    Item          Wt
   "Motor"       100
   "Bearing"      20
   "Mount"       220
Robin561-VisitorAuthor
Thanks, That works for me.
Robin
