MATHCAD User-defined functions in FORTRAN
Good evening.
I am trying to use user-defined FORTRAN functions in MATHCAD PRIME 10. Unfortunately I do not have the Compaq compiler mentioned in the online help. Does anyone know if other compiler such as Intel OneAPI can be used and if the procedure is the same as described in the online help? My concern is about the libraries that MATHCAD PRIME needs that are Compaq proprietary and the compiler is no longer on the market. Thanks.
terryhendicott
The help states:-
"Creating New Custom Functions
The process of creating user custom functions involves the following steps:
•Writing the source code in C or C++ (or wrapping Fortran code in a C wrapper).
About Using Fortran in Your Custom Functions
You can wrap compiled Fortran code in C or C++, allowing PTC Mathcad to run it. In this way, legacy Fortran code can be reused as a PTC Mathcad Prime function
This means you can use any fortran compiler that can have its code wrapped in C or C++ will work
Cheers
Terry
terryhendicott
The help states:-
Cheers
Terry
gianfry10-MarbleAuthor
Thank you Terry for the answer.
I tried  your hint and after some tests I was able to do it.
To be honest I was stuck because of the information in the MATHCAD PRIME online help, also mentioning the FORTRAN libraries.
I wanted to create an exportable fortran library as DLL, but the C++ code wrapping the FORTRAN one is a better idea.
Gianfranco
Hi Gianfranco, could you give an example of the implementation? Best regards, Peter
