Mathcad (V15 M030) Excel add-in - is there a manual?
I've downloaded the mathcad excel add-in for V15 M030 http://www.ptc.com/support/mathcad_downloads.htm, but can't find any instructions on its proper install and use.
Are there any proper manuals for it.
such as how to enable the add-in
how to insert a specific sheet as an add-in
how to select data ranges from excel, and how to export data to excel.
etc.
etc.
Philip
I have now had it confirmed by PTC support that the add-in doesn't support Excel 2010 integration.
I've asked that they add a note to the downloads page to correctly indicate that limitation.
I didn't get / push for a response about the lack of a manual 😉
Philip
To clarify, this is for Windows 7 and for Excel 2010 Professional.
I am not sure Mathcad 15 supports Excel 2010, see here.
http://communities.ptc.com/message/159274#159274
Having said that other users have reported that they have had no issues.
What are you trying to use Excel for, embedded objects?
I'm using Mathcad 15 and excel 2010, the add-in works well...There is a help file for the add-in.
Well that is good to know. Do you have a copy of the help file?
