Maximum Value of a Piecewise Function
- 2 replies
- 1436 views
- Translate All
I am working on a simply supported beam calculator. I have everything up and working but I am having trouble when it comes to determining the maximum of the displacement and it's corresponding x value.
In the collapsible area under the loads you can see I have the various displacement equations and to find the total displacement I sum them up. I then need to find where this value is a maximum but I don't know how to do it other than reading it off the graph.
Is there a more elegant way to determine the maximum so I can define a function for maximum displacement and corresponding x-location. I have attached the sheet for reference.
Callum
