Mar 21, 2010 7:00 AM UTC
MC 14 doesnt stop
I am running Mathcad 14.0 M035 (14.0.3.374 []) on Windows 7 Ultimate 64 bit.
Every time I close the programm, the process mathcad.exe*32 does not close. I only can terminate it with the taskmanager.
If I do not terminate the process and start and close mc again, 2 such proccesse get stuck in the processlist.
I can reproduce this on all of my Windows 7/64 machines.
>Ultimate 64 bit.
>the taskmanager.
This is a known bug of M030 and its not Win7 nor 64Bit specific.
If you don't use the Windchill integration you may want to use M030 which doesn't show this bug. To the best of my knowledge M035 brings no furher features or bugfixes - Windchill only.
Rmix
BTW - is it only me having problem posting a reply. Nearly everytime when I press the Post-Button I get an Errormessage. Using the back-Button of my browser and sending again usually works fine then.
The Error-Message is:
Error in WebBoard
An internal error has occurred in WebBoard.
03/21/2010 10:01:30 (MATH009) (Mathcad2000) Reginald Meixner (rmix22) ERROR in WebBoardServer4.WB_MsgDone(): #13: Type mismatch
Please note what you were doing when this problem occurred, so we can identify and correct it. Write down the Web page you were using, any data you may have entered into a form or search box, and anything else that may help us duplicate the problem. Then contact the administrator of this service:
Mar 22, 2010 7:00 AM UTC
I believe you meant to write that it's a known bug of M035, not M030.
Mona
Mar 23, 2010 7:00 AM UTC
Yes, of course. Its a M035 bug. Sorry for the typo
RMix
>not M030.
>Mona
