Moment-Curvature Analysis - Rotations and Displacements
- 9 replies
- 9360 views
- Translate All
Hello PTC Community,
I am attempting to utilize my Moment-Curvature Interaction (M-C) to calculate beam rotations and displacements. Currently, I have a worksheet that writes my M-C data to a text file (not included here); the attached worksheet reads the data file, creates a linear interpolation function describing moment as a function of curvature. Next, I have a simply-supported beam loaded with equal symmetrically placed point loads (0.5P); I have defined the moment diagram as a piecewise linear function of length (x).
My goal is map curvatures across the length of the beam, using moments as the method for "matching" the curvatures to length. The next step(s) of calculating rotations and displacements are straightforward after this.
The attached Mathcad Prime 3.0 file attempts to solve for the corresponding curvature that satisfies M(c)=M(x), where c = curvatures from the interaction diagram, and x = position along the length of beam. However, the curvatures I calculate using the Solve Block and "Minerr" are nowhere close to being correct.
Can anybody help with ideas of how to translate curvatures to position??
