Multi-Axle Steering Mechanism
I am working on a multi-axle steering mechanism. Problem with Creo 2.0 BMX (Feasibility / Optimisation) is it does not converge. A convergence solution we found in Matlab SimMechanics worked but again the geometry is lot simple.
I wish if ptc people can solve it using Creo/MathCAD Prime.
I will share complete problem with CAD model in Creo 2.0 if interest is shown here.
The Mathcad subspace here might not be the best location to place the question (if it is a question at all?).
BTW, you have to understand that this is a user driven forum. Most of the posters here are not - god forbid - "ptc people".
A CAD model posted here will be of no use. Even if it could be opened, it will be impossible to determine what you are trying to achieve with that explanation.
Maybe you should initially post your problem here.
http://communities.ptc.com/community/creo
May be this
http://communities.ptc.com/groups/kinematic-models-in-mathcad
will be any help for you.
ctraining4-ParticipantAuthor
Thanks for your replies. All I want is integration of Creo 2 or 3 with MathCAD Prime.
Have you read the help files to see if this is possible?
