Multiple Function Fitting
- 8 replies
- 5313 views
- Translate All
I am somewhat new to fitting data using Mathcad (15), so I apologise if this is a stupid question.
I have experimental data on the temperature dependence of the molar volume (Vm) and isochoric specific heat (Cv) of a compound.The former is related to the internal energy, the latter to the first derivative of the internal energy. If I use Debye-based models, then the Debye temperature is a common variable for both functions, the molar volume includes two additional variables. The number of data points for the two independent data sets is different. I can fit each function separately, but I wish to fit them simultaneousy to determine the best estimate of the Debye temperature.
Is there a simple way of carrying out multiple function fitting in Mathcad?
Many thanks
Kevin
