Multiple input values to a differential solve block
- 3 replies
- 4261 views
- Translate All
It would appear logical that one should be able to turn the output variable of a solve block such as attached into a function which can then invoke the solve block numerous times in order to solve a differential equation and generate multiple output functions. In other words, a series of input variables which are defined before entering the solve block can be called upon to solve the differential equation multiple time. Can someone explain to me how this can be done using the attached example.
Thanking you in advance
Mark Buckton
