Jun 21, 2017 7:34 PM UTC
multiple licenses for side by side install
i have a permanent license for MC Prime 3.0 and temporary one for 4.0 and both versions of prime are installed.  when i locate and apply the temporary 4.0 license to prime 4.0, my 3.0 installation also takes this temporary license.  when i apply my 3.0 license in 3.0, it modifies the license applied to 4.0 rendering it unlicensed.  can i apply different license files to side by side versions of Prime??
Jun 21, 2017 10:19 PM UTC
I am not sure if this would work, but you could try your luck using the environment variable LM_LICENSE_FILE the value of which is a semicolon separated list of license servers. The local license file for P30 should be first and the license flex-server with the P4 license second. So P4 should first look at the P30 license which is not valid for P40 and so further looks at the license server.
Jun 22, 2017 7:39 AM UTC
Hello, Blake, I have logged a case on your behalf and one of our technical support engineer will be in contact ASAP.
Case Number: 13742747
Link to Case: https://www.ptc.com/appserver/cs/view/case.jsp?n=13742747
