Multiple Outputs from Solveblock - Intermediate Variables as Output included
- 8 replies
- 2831 views
- Translate All
Looking to get multiple outputs from a solve block where some of the outputs are intermediate stages in the calculations. I'm getting an error when I try the normal things one might think of such as entering Tso(Tfo) and Tsi(Tfo). Looking to use the solve block becuase it is faster, but I can stick with the programmed version if that is necessary.
I like the Solve block version more, becuase the accuracy should be greater regarding the equations due to where I inserted the radiation componenet, though I think they should be fairly close for the majority of items.
