Werner_EAnswer
Whenever in  any calculation a NaN is involved, the result is NaN.
Maybe a utility  function to do the vector multiplication ignoring any multiplications with NaN involved could help:
Applied to your calculation it looks like this:
Is this somewhere near to what you expected?
The calculation takes some time as Prime has to multiply 3669*2=7338 times two 3670x1 vectors  and a user-written function using augment and filterNaN isn't very fast.
Prime 9 sheet attached
23-Emerald V
@YA_10963798 wrote:
I don't know why I getting this kind of result.. I tried everything. It is on page 15 . I use prime 9
When you multiply any pair of vectors that contain at least one NaN, the result is also a NaN.
Stuart
I've got Mathcad Prime 10, so I can't post a worksheet that's useful to you.  Sorry.
so that means the whole results will be NaN.. and that will erase all other results?.
23-Emerald V
Yes, I’m afraid so.
Stuart
Werner_E25-Diamond IAnswer
Thank you that solved my problem
