Need advice plz how to manage the NaN in the condition
Hey,
community.
I could manage so far the loadcaseprogramming but i have a problem how to get rid with the "NaN" value.
At Page 8 of the mathcad file i need the smalest safety factor which i calculate out of the 5 Calculations.
BUT WITHOUT THE NAN VALUE. When i do a minimum it shows me always a 0 when NaN occurs anywhere,
How Can i write the condition with excluding a zero result?
I just want to see the minimum safety factor without the zero.
Is there a Possibility to comprimise my programmcode?
Best thx 😃
Can you guarantee that all the values Re.Ti, i=1,2,3,4,5 are positive (apart from the possibility of being NaN)?
Then a very easy solution is available (-> look for the negative max of the values -Re.Ti)
Otherwise a three-line routine could be used:
R
Hmm maybe i described little wrong:
its about the safety factors on Page 8
I need the smallest safety factor i calculate out of the 5.
When i do the negativ maximum im getting the highest value of the safety factor.
I need to look of the smallest safety factor excluding the NaN
im always getting the Zero as minimal value and not the smallest of the other one hmm 😞
