Need help approximating a polynomial & least square fit
Hi, I'm having trouble with the attached document. I'm not getting the right answers.... or any answers at all.
Jackie
Here's a hint. If you get a strange answer from a function, it's always a good idea to look at what the inputs to that function are. Evaluate L. I think you will then see the cause of the problem
Jacqueline,
See in attached file
