18-Opal
Neg Seq Ended Fault locator.mcdx
- 0 replies
- 862 views
- Translate All
File to locate faults on a Transmission Line. Based on Schweitzer Negative sequence method. File can be modified to accept phase currents and voltages and then calculating the Negative sequence values.
