Non-linear equations system
Trying to solve a systems of 3 equations with 3 unknowns by means of SOLVE BLOCK and MINERR function. (or find). It doesn't provide any error message but it seems not to calculate any root; it simply provides the three guessed values as the results without running any iteration.
terryhendicott
Attach the file please.
Cheers
Terry
Here the file and the solved example from a book.
Thanks a lot!
terryhendicott
I have carefully checked your work, It is correct.
I also get the wrong answer compared to the original.
I trust someone from PTC is watching this thread and can see the errors in Prime.
Cheers
Terry
