Non- linear equations system solution but i want my answer to be matrix form
Hello since im trying to find the unknown with 6 different initial values and 6 non-linear equations I try to use find but I cant obtain the value but there is one variables in the equation got counter.Hope u guys can check for me.
Werner_EAnswer
Guess the attached sheet should help
see pls attach
aizham31-VisitorAuthor
Okay thank you so much for your help but the 6 unknown only for  one V or should I say speed but how do I present the data for the 6 unknowns for the 10 different V in matrix or table is it possible?There are some modifications I have made from your Mathcad..
You can create the user function Ans(I):=Find(...
