Nonlinear optimization (derivative free) in Mathcad?
Hi All,
Could someone tell me if there's a spreadsheet available, or any solution with built in functions to perform a Nelder-Mead simplex optimization of multi-variable function?
Zsolt
There is no built-in function, but why do you want to use this algorithm? Because it doesn't require derivatives, or for some other reason?
KGMEurope1-VisitorAuthor
I have an expression like: G(y,x,c,v,b,n)
The expression between variables and G is not closed form, it's self-written function.
I want to find the closest point of G=0 surface to the origo.
Look up "minerr" in the help. It should do what you want. If you can't get it working post a worksheet with your problem (to do so, click on "Use Advanced editor" at the top right of the edit dialog).
