Noob question: How do I rearrange a large equation?
  • February 17, 2014
  • 3466 views
As a basic example
{v = u + at
Rearrange for a.}
I literally cant find the answer anywhere on google, youtube, or these forums. Please bear with me if its a simple question, I only got my teeth into the program yesterday. Its the one function I need to speed things up. I don't want to have to do it on paper every couple of minutes.
Many Thanks,
Ben
So I guess you should spend some time on the help pages, in your case especially those dealing with symbolic operations. Look up the command "solve".
Ok so I use the solve -> function but what keyword do I use?? I tried rewrite but can't get it to work!
The keyword is solve, followed by a comma and then the variable name you want to solve for.
