ODE solve help : predefine a function
It would be super great to have any suggestions for the mathcad file I have attached.. Please check the file, I have described it there..
Thanks!
Not sure if I understand correctly what you want to achieve,
I wonder why you would want to introduce a third unknown function in the solve block which is dependent in a simple way on the function N.p which you are solving for.
Are you looking for something like this:
23-Emerald I
How about this??
I guess the initial value of M.p should not be 1 but 30 ((1-delta2)*P.N.)
But I wonder why the result is so much different!?
EDIT: I felt into the same trapdoor. It should rather be like this:
math1-VisitorAuthor
i think the picture is not attached well.. I cannot see it..
math1-VisitorAuthor
I think it is getting a bit deviated from i want to achieve.. I don't want to add an extra M.p on the ODE block, I am only trying to simplify my equations.
What i trying to achieve is to make the C.p(t) equation look a bit simple by shrinking ((1-delta2)*P.N' N.p(t)) into one variable such as M.p(t).
such as to predefine a variable,
M.p(t) = (1-delta).P.N*N.p(t)
So that,
C.p(t) = M.p(t) - µ.pCp(t)
or if this is possible?
Look at Fred's post and the picture I just posted a second time.
Or maybe the second pic in my first replay, if you still want to solve for N.p and not M.p.
math1-VisitorAuthor
But.. did u read the post that i replied recently?
I dont want to introduce a third unknown function, I would just like to simplify my equations by predefining them
