6-Contributor
Dec 2, 2021 2:05 PM UTC
ODE Solve issue
Hi all,
I am trying to figure out if it is (mathematically) possible to obtain a x(y) function via the following system with odesolve:
dx/dy=F(x)
Do you guys have a idea if it is possible in mathcad, and if so, how?
Werner_EAnswer
Dec 2, 2021 2:47 PM UTC
As x is your function and dependent on y, you have to always write x(y) and not just x!
And the initial condition can't be that of F but that of the function to solve for -> x(0)=...
After all, in your example F(0)=5 and not 4 🙂
The plots also show the exact symbolic solution of your ODE.
Dec 2, 2021 2:10 PM UTC
Give an example and post the initial worksheet please.
Here is an example done in MC15
If you use Prime keep in mind that solve blocks and the syntax for odesolve is different there.
6-Contributor
Dec 2, 2021 2:15 PM UTC
So something like this. I want to plot x versus y, given the equations in the screenshot. (this is a simplified version of what i want to actually solve).
Werner_E25-Diamond IAnswer
