odesolve problem #2 SOLVED
- 7 replies
- 2742 views
- Translate All
Hi
If you scroll (almost) all the way down you will find the variable "v.ho". Generally "h" stands for helicopter while "l" stands for load. -> "v.ho" is the inital velocity of the helicopter (with the slung load underneath). However if I change v.ho to a slightly higher value there's something strange going on. Can you tell me what it is and why it is?
If you have some suggestion for improvement of the file you're invited to tell me
many thanks in advance
